GE Washer Leaking
I have seen posts similar, but when looking at the parts there were several to choose from I guess is why I am posting.
My GE washer just started leaking (small amount) into the tub and does not stop unless the water valve is turned off. Turned on, it leaks. Cold water does not leak, just the hot water. I have it turned off for now, but would like to purchase the part and was wondering as to the level of expertise in replacing the part needed.
Thanks!
