washer leaking on inside of tub
my washer works great but it recently started leaking hot,cold water on the inside of the tub so i have to immediately remove the cloths as soon as the cycle is complete or the cloths will get soaking wet again when the washer is not in use i have to turn the water off at the faucet or it will slowly fill up again it can become half full in 2 days i feel like it is some type of washer on the inside but where and how do i replace this ?
Sounds like your valve assembly is stickly slightly open, so I would replace it. Here is the part
AP3884017
To get to it, take off the front panel by inserting a screw driver in the gap between the top and the front near the edges to release clips that hold the front panel on. You can now take out the screws that hold the top on and get to the valve assembly.
thanks for the reply this gives me a starting point to check , thanks
