I have a GE Profile PVM2070SM1SS microwave.
In the last few weeks it has started behaving "strangely" when heating/cooking.
Sometimes, it will work fine for days at a time.
Then for a little while (days, etc…) it won’t work properly as follows:
- This happens when using either the timed cook or sensor cook.
- The microwave will start up properly (turn table will start, count down will begin, fan flap will open, fan will start up)
- After about 3 - 5 seconds (typically) it will "shut down". Cooking will stop. Fan flap will retract. Fans and turn tables will shut off.
- Once it has completed this "reset", it will start up again from where it left off (ie: if countdown had reached 54 seconds left, it will resume from 54 seconds)
- After doing this a few times, it will just stop. Cooking will stop however the vent flap will NOT retract.
- If the Clock panel is on, a single digit number will appear. This number is not the same every time.
- Microwave must be unplugged to "reset" it.
What is in the chamber gets warm while it’s running (ie: heating water) so there it seems all the "normal" cooking function is working.
The GE customer support suggested the control board need replacing. However there seems to be 2 control boards, and both are fairly expensive…
I’m also open to the idea of looking at something else
