GE PROFILE Fridge Model : GSH252GPASS
Hi,
Good Morning!. We have a GE Profile side by side refridgerator. the issue we are having is the Fresh food side is warm
and vegetables are smelling and it is warm. I pulled the fridge and cleaned the dust build-up from the coil behind and
the fan. The fan in front of the coil is working. Compressor works, freezer side making ice. Evaporator fan works,
collect pan has water at the bottom of the fridge back side.
Changed the damper thermistor and it is working. but the air flow is not great. Checked the evaporator fan and it is
working, removed the freezer side back panel, saw slight frost build up at the bottom and took 4 min of hair drier time
to make it completely dry. Noticed the thermostat Back side is bulged(might need to be replaced i believe).
Checked the fresh food side bottom vent for any blockage - none, kept a dollar bill and it sticks to the vent, looks like
the air is flowing, but not great though.
The mother board was changed recently by a tech and the fridge worked for about an year now.
My questions are these.
[B]1) How to check the thermistor, thermostat, heating filament using a multi meter. what are the good-bad meeter readings
for these parts on a multi meter and what are the points that I need to keep my probs of multimeter to test.
- How to improve the air circulation from the freezer to firdge side - I read some thing about temperature control board
what is this and how do I test this.( Should I replace the existing working evaporator fan) is there any other fans that
needs to be checked or replaced in this model? I do not see one in the fresh food side.
- I also read from internet that there is a self diagnosis to tell what is working okay and what part is bad. and some
[/B]
ind of table to tell the numbers to use. is there one for this model if yes, can you share this info.
I am saving the food for now by opening the damper door, disconnected damper chords. Cannot continue this for long.
Please help…
Thanks & Regards,
Bala
