GE Profile Spacemaker 2.0
Son ran microwave for up to 28 minutes without anything in the microwave thinking he was using timer. Obviously he was not using as just timer, rather he was heating as the power vent was tilted out as in use while cooking.
The unit is completely and totally dead. Tested outlet and it is fine. Removed unit from wall and opened unit. The little "trouble shooting" manual located inside the unit suggests first replacing the fuses. That sounds logical to me, however someone suggested the magnatron thermostat probably went. If that was the case the unit simply would not heat, correct? It would not completely kill the unit correct?
Thanks for the help!
