Our GE Profile Space-maker XL1800 when run at full power shuts off in 2-4 seconds and displays power interruption. The display flicker also when it shuts off. If you start it at power level of 8 it works fine.
[SIZE=3]It is hard to say for sure but I think it is in the control board. [/SIZE]
[SIZE=3][/SIZE]
[SIZE=3][/SIZE]
[SIZE=3][/SIZE]
http://www.appliance-repair-it.com/range-repair.html
— Begin quote from jerryxl1800;154347
Mine does the same. Have you found a fix for it? I’ve called a service repairman and will post if/when I get new information.
[SIZE=3]I have never personally seen this happen but I have read post about the magnetron interfering with the control board. Try this page [/SIZE][SIZE=3]http://forum.appliancepartspros.com/microwave-repair/63025-why-no-answer-2-second-shut-off-issue-spacemaker.html[/SIZE]
[SIZE=3] [/SIZE]
[SIZE=3]I have never run across the in the field but apparently a common problem. [/SIZE]
Our microwave makes a very loud noise when running. Is this repairable?
We have a similar problem. The noise is like a growling noise. I remove the ‘lazy susan’ dish on the inside, and it still makes the same noise. Have you had any luck dealing with it?
