I have a GE Profile washer (top loader) that has no power. I verified the outlet is good and so is the power cord. The start button usually displays the amout of time or a zero but now I have nothing. If I unplug the washer for a few minutes and then plug it back in, I hear a little click under the backsplash. That makes me think that power is attempting to get to the control panel and that is where the failure lies. Is there a way to determine if the control panel is getting power? Is there a way to determine if the cause is somewhere else? Thanks.
Hi.
Get access to the control board.
Locate 2pin plug with RB wire and 10 pin plug with WR wire. With washer plugged in check for 120VAC between this two wires.
If proper voltage present - replace the main control board.
Here are the breakdown diagrams and http://www.appliancepartspros.com/controls-backsplash-parts-for-ge-wpre6150k1wt.html
Post the results.
Simon.
