GE Profile Washer
GE Profile washer starts to fill and runs a minute or less then shuts off. I have noticed that I can tap the control panel on the right front(not on the switches but on the frame of the control panel and it will immediately cut off.
Would appreciate a reply and suggestion of how to repair it. If i have to take the control panel cover off, how do I do that?
Thanks,
Frank
Hi Frank,
You have to open the control panel (remove a few screws on top of the control panel) and check all wires to the control board.
If there is nothing wrong then the control board has to be replaced.
  • The part number for the control assembly is AP3156198
Here are the break down diagrams for the GE washer http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=511556&&model_id=230718
