Our Ge Profile Will Do Everything But Spin The Clothes… A Repair Guy Told Us It Was The Motor But We Had Our Tested And It Was Fine. NOW WE HAVE NO IDEA.
Remove the front panel and check the lid switch for continuity or bypass it and see if it’ll spin.
Here are the break down diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=22282425&&model_id=5205800
How did you check the motor?
We Bought A Brand New One And It Did The Same Thing.
Ratchet the WATER LEVEL switch back and forth a few times, Sometimes they stick, and it wont spin until the water has drained,(Hence, the switch has to work so it will spin!!!)
Gene said:
Remove the front panel and check the lid switch for continuity or bypass it and see if it’ll spin.Here are the break down diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=22282425&&model_id=5205800
Did you do it? If you did what was the result?
we had clunkiing, gear noises an then it quite and gave a "detect problem message."
After a little investigation we found a lose nut!!! it was on the very bottom of the unit;
laid the washer on it’s ‘face’ and tightened up the 15/16" nut and off we go. the hardest part was holding the brum/basket to get enoough tightening torque on the nut.
We’re sooooo glad to avoid a costly expense- hope it helps you too!
