Hi
I have a GE refrigerator the freezer section of which is no longer cooling well as also the refrigerator.
There is a lot of ice on the rear wall of the freezer. I checked the defrost heater for continuity and it seems fine.
I ended up changing the main board, part # 801 here.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=210447&diagram_id=22341225#d22341225
However, after working fine for a few days, the problem is back.
Not sure what else do I need to change if at all.
Any help is much appreciated.
Thanks!
Here are the parts
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=GSS25QFMBB
Did you check the defrost thermostat Section 5 Item 240.
Also if it looks bulged out I would replace it.
Probably not a bad idea to replace the sensor, Item 241.
If the fan is running OK I would not replace it, just a waste of money.
Sounds more like a defrost problem than a fan problem.
— Begin quote from denman;215153
Perfect. Thanks much…
I will order only those 2 parts and get back to you in a couple of days.
