GE s/s caught in defrost(very warm) freeze cycle(
moved this s/s out into the garage as my storage refrig. because ice maker ate itself. So after being in the garage working find for a couple of weeks it defrosted and got quite warm, so I took the bottom panel off cleaned the whole bottom fan/comp./ basically everything I could clean. Took the inside back wall looked at the evap. coils everything looked good. Put everything back together plugged back in and it started the whole cycle over again. I tried search here in the forum and nothing matched, so started this thread. I’m fairly good at checking/repair so any help suggestions would be appreciated. Thanks in advance Greg
