Hi All,
I set about fixing my fridge this evening since the compressor stopped yesterday and here is what I have found out.
Compressor Seems good. Resistance is 10, 6 , 4 ohms across the bottom two, left and top, to and right pegs respectively
Relay is good, no rattling and tests at 7 ohms
I checked for voltage at the terminals of the compressor, and I get 0V. This is with the fan running for coil so that would indicate the thermostat is working. The only thing left I can think of is the Control Board. Is that Correct? Is there anything else I should check?
Thank You
