GE side-by-side
An ice layer builds up at the bottom of the freezer and prevents the door from closing completly. When the door seal is not seated properly when the door is not completly closed water is constantly leaking out from the bottom of the freazer door. Could there be a drain hole cloged or something? It might be possable that since this modle is frost-free and if a drain is cloged then the water from defrosing would lay in the bottom of the freezer and turn to ice.
I have a Jenn-Air dish washer that is not pumping water through the sprayers. I have checked to see that nothing is clogged and I can hear the inpeller spinning when the machine is on but it sounds like it slows way down as the presure builds and isn’t turning fast enough to push water up the sprayers. Any ideas?
Disassemble the pump to access the chopper and seals (#8 & #9 on the [B]Service manual and inspect all parts. Follow the disassembly instructions in the [URL="http://servicematters.com/maytag_library/docs/16021814.pdf).
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5169916
