Our GE top loader sprung a leak at the shaft. I replaced the tub seal (the old one was much more the consistency of a hockey puck than rubber so my confidence level was high), but it is still leaking. I pulled it back apart, and the seal had come up out of its seat in the outer tub. I re-seated the seal, but it still leaks from the bottom. I disassembled things again, and the seal had stayed in place. Any ideas before I give in and call a repairman? Would this be a sign that the shaft itself coming into the machine is damaged?
Related topics
GE Top Load Washer Leaking down Shaft | 2 | 5241 | September 28, 2015 | |
Ge Top Load Washer | 1 | 867 | April 12, 2014 | |
GE washing machine leaking help | 1 | 146 | June 18, 2022 | |
Tub leaking again GE washer | 4 | 1212 | January 12, 2014 | |
ge washer leaks from bottom center of tub | 2 | 3431 | August 14, 2010 |
