Ge Triton xl
I recently replaced the detergent assembly and in doing so ripped the front panel electrical source off when the door fell apart. Do I have to buy a whole new front panel or can I just replace the electrical source that ripped off the mother board?
Here is a parts breakdown
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=gsd6660g02ss
Could you please explain it a little better.
There are a number of plugs going to the control board.
Which one ripped off?
Is the plug damaged?
Is the control board damaged?
part 901 for this model the strip of tape on the back of this part ripped in half. It is electrical and attaches to motherboard. I can’t explain it much better because I don’t know the exact part name.
Just to confirm what ripped in half.
It is the cable that is sticking out on the right hand side of the Part 901 diagram.
It is a ribbon cable.
To get it you have to buy the complete part 901 (Keypad)
It is hard wired to the keypad.
If you have a friend who is into electronics they may be able to fix it.
Taking it to a shop would probably cost you as much as a new keypad.
