GE Wall Oven Locked and Dead
[SIZE=3]Yesterday I put the oven on self clean (I know never do it!).After about 3 hours I noticed the display was blank, and the oven cooling fan was still working. When the fan finally stopped cooling down the oven it is now "locked and dead". I have replaced the control board and the bake element in the last 8 months.It is not the breaker.I have removed the front faceplate of the oven and can see no burn marks on the control panel.Is there some sort of fusible link or switch that could cause this?[/SIZE]
So now I peeled the motor off the lock motor and got the door open.The oven displaypanel is still blank, but when I opened the door the inside light comes on.Any ideas as to what I need to replace/test on my oven?
— Begin quote from vqamarty;346223
