Ge washer crazy
When i run a load of clothes . Look at clothes all wet didn’t spin .Put on manual spin push start button and the light jumps from spin to wash and makes some noise put isn’t working . Try starting it over from the start set knob lights light push start button and the fill light jumps from fill to soak and wash . Machine makes strange noises clicks and pops .Washer wont work right at all . I already replaced the control board .When i replaced the control board it worked fine for two days then did the same thing again .The led light on the mother board flashes 1 second on and 1 second off normal .:confused: It seems like it does know what it’s doing ? One time it went on spin and wouldn’t stop spinning lasted like 10 minutes ?
