GE Washer door stuck on lock
Washer worked fine all morning, went to put another load in the washer and pressed start. The "door lock" came up on the screen and the door locked. But the washer wont start. It just stays locked, even after unplugging it and powering off. The machine is just a few months old and has worked perfectly up until now. I have no idea what is wrong. I emptied the pump on the bottom, there was nothing in there except a few cups of water. Now I cant open the door, I dont know if there is a manual open button or not.
Also, is there a way to figure out the error code or anything? Thanks in advance.
The model number will not come up, probably too new for us. If it is less than one year old the problem should be covered under the factory warranty.
Call GE and tell them to get out there and fix it.
