Ge Washer Help
i am geting water from under the washer could it be a hole in the tub
[SIZE=3]Recheck your model number and post this under washer repair and we will help you. [/SIZE]
— Begin quote from applianceman;115635
model number-wa5669malwh
[SIZE=3]On this model there is a possibility the tub has a hole in it and if it does it is time for a new one. But you need to remove the back and attempt to see where the water is coming from. The water pump will often leak and also there is a rubber boot at the bottom of the tub that will sometimes leak. Post what you find. http://www.appliance-repair-it.com/clothes-washer-repair.html[/SIZE]
