Ge washer only drains
Ge front load washer, powers up, hit start drain pump kicks on, will not fill, no movement from inner tub, replaced inverter and main control, ran diagnostic on the pressure switch, fills to all levels then drains. the machine will do nothing but run the drain pump, after a few minutes it shuts down and the start light is blinking, any help would be appreciated.
