GE Washer problems with cycles
Washing machine fills for wash cycle. It agitates and then drains after wash cycle. Will not refill for the rinse cycle. Then won’t go into spin cycle. I can hear the timer running but doesn’t seem to advance into the rinse or spin cycle. Have replaced the lid switch assembly and the pressure switch/tube. Still no results. What is going on here???
I am not sure exactly when the problem occurs. If it will go through the wash cycle including spin, then it is likely a timer or control problem.
I cannot get your model number to come up, so that is about the best I can do.
