GE Washer roaring noise while spinning, but everything else is fine
My GE washer roars like a 747 on takeoff, but everything is working. Good water pump, good timer, good lid switch, no water leaks, no oil leaks. One time back the spinning stopped working and I freed it up by hand by turning the basket.
What could be the problem? Transmission, bearings??? I would like to keep the replacement parts to a minimum, but I am open to anyone’s ideas. It would be a shame to replace a transmission if it is only bearing that is easily replaceable. Any ideas? Thanks.
