GE washing machine fills with water but does nothing else. The time works.
Jim
Jim
Hi jrgreulich
Most likely the problem with your washer is a bad lid switch. Unfortunately the GE does not make it any longer.
The lid switch is not bad
i have the same prob. the lid switch is still good. i checked with my multi-meter. I had a sock stuck in the pump the burnt my I/O relay. replaced that and now it still wont do anything but fill with water. Yes i removed the sock.
