I don’t know how old the washer is as I got it used. It’s worked fine until today. I let it fill, added soap, then I put a load of laundry in, pushed the dial in and nothing happened. I can hear a quiet noise around the dial area. When I moved the "load size" dial it added more water and then stopped when I moved it back. I changed the outlet, checked the cord. All seem fine.
I played around a little with the are that tells the washer that the lid is on. It didn’t seem like it did anything so it’s possible that switch is bad?
I’ve been doing a little browsing online to trouble shoot and it seems like I need to remove the front panel. I can’t figure that out either.
Help!
