The washer will fill the water and stop where it is supposed to. From that point nothing will happen.
I’ve tried the following:
- Checked drain hose for blockage. OK
- Bypassed lid switch. Didn’t help. I did turn the dial to spin after bypassing and that works so I don’t think it is the motor.
I’m assuming once filled it should go right to the agitate stage?
Does anyone know what I should try next?
