I have a GE washer and the inner tub will not stay tight. The problems started when the machine got off balance. I replaced the hub nut thinking the threads may have been stripped. This lasted for two loads and the tub loosened again. I took it apart again and found that the ring split/split ring was worn very badly. I replaced this and retightened the hub nut. It did not stay tight even through one load. I noticed that the edges of the balance ring are very worn and was wondering if I should also replace this or if there are any other parts I should look at and possibly replace. Any suggestions you could provide would be much appreciated!!
Related topics
| Topic | Replies | Views | Activity | |
| GE Washer hub nut loosens | 5 | 9262 | December 23, 2009 | |
| GE top loader with loose tub | 5 | 17023 | March 7, 2011 | |
| GE Profile washer fills, drains, agitates, but won't spin | 5 | 8749 | October 29, 2009 | |
| washing machine hub GE | 0 | 2307 | January 1, 2008 | |
| GE washer inner basket out of control | 2 | 2072 | September 29, 2010 |
