I have a older ge washer model wwa8320gal I couldnt get it to spin or drain so I jumped the lid switch and got it to spin in the rinse cycle and ordered new switch and then went back to test it again little bit later but it will only fill now won’t agitate spin or drain.it will only fill with water and when its set to all other cycles u can hear the timer ticking but it does nothing.should have new lid switch tomorrow and will install that and see what happens but was wondering what else could be the problem seeing as when I first jumped the switch it did spin in rinse cycle.
Ok i got new switch and hooked it up plugged it in and heard timer ticking but wouldn’t do anything but fill only.
So I left it plugged in and went and took a 10 min break came back and tried it again and now it is working.
Is that maybe how u reset motor or something I am happy it is working now and hope it stays that way but now curious if that’s what happened
Thanks to everyone for taking the time to to post on these forums I have searched a lot of post and have learned a lot.
