Washer is 3 years old, recently had an issue with water under the washer, so I pulled it out, checked hose connections, cleaned out drain pipe, and removed the front panel and detached the top (except for the lid switch).
I determined the leak to just have been from splashing through cycles with too much water for too little clothes, as water was coming out of the flood drain pipe during agitation (no leaking when filled for super load).
Relieved, I put the top panel back on and did another test – now it does everything it’s supposed to except it no longer will agitate or spin. It will go through a whole cycle (fill & drain through each part of the cycle), but it won’t move.
I found suggestions to try unplugging to reset the washer, I checked the lid switch which was pulled out slightly from my removing/reattaching the top and I read that if the lid switch was a problem, it wouldn’t drain properly.
The green light blinks when it should be agitating during the wash cycle – 4 brief blinks in a row, then about 6 or 7 seconds off, and this repeats.
I’m not real inclined with this stuff, but it seems like it must be simple since it was just working earlier today. Is it possible I accidentally cut or detached a wire from the control panel when re-attaching the top? I did hear a kind of popping noise when putting it back on, but figured it was the lid switch.
— EDIT: Now that I look closer at the lid switch piece that has wires running to the motor, it looks like the small silver wire may have snapped apart in the middle (I’m not sure if this was one piece to begin with). Could this be the root cause for the motor never agitating/spinning? How do I bypass the lid switch to test this?
— EDIT 2: Pretty sure it’s the lid switch – I didn’t realize there is actually a tiny glass tube that’s supposed to be around the silver wire in the lid switch assembly, and this tube is busted with the wire actually sticking out. Any quick fix remedy for this, or will I have to replace the whole lid switch assembly?
Any help/ideas appreciated!
Thanks,
Jeff
