GE washer won't spin
Washer cycles and drains fine but it only spins for about 5 seconds.
GE does not sell parts for the motor separate which means you have to buy the whole motor with the clutch assembly.
Depends on the age and condition.
Hello!
My Maytag electic Intellidry dryer makes a screeching metal-on-metal sound on-and off.
How do I open the lid to look inside?
What are a few possible sources of the noise?
Maytag Bob:(
Maytag washer filled and washed load ok but would not drain water.
Washer power is from a generater due to hurricane Gustav. Could low power or blown fuse be my problem? Any other suggestions?
had the same issue come up with my dryer and it this guide was perfect. Thank you.
So I did the above diagnosis and have since ordered new Rear Drum Support Rollers and Axels. That will solve the metal on metal screeching, but since reassembling my dryer the start button does not work. The light inside the cabinet will come on with the door open and the sensor in the door seems to work because it extinguishes the light if I press it with my finger. Also, the moisture monitor seems to illuminate when I press the start button, but no action occurs from the dryer. It does not make a sound. Any suggestions are greatly appreciated!
What is the complete model number of the dryer?
Mde9606ayw is the model number.
The first thing I would do is disassemble the dryer and check all wire connections, especial the wires connected to the door switch.
Then check the thermal fuse (10 at the [B]diagram[/B]) for continuity.
Here are the breakdown diagrams and http://www.appliancepartspros.com/parts-for-maytag-mde9606ayw.html
