I have a problem with my washer machine, it does agitate and drain the water, but does not spin. I checked the belt and is good.When the machine hit the spin cycle you can hear the water pump and the motor working even though that motor shaft is no moving at all, but does not spin. After about 5 minutes of listening to the soun(motor, water pump)the motor start getting blazing hot.Please guys i need your help!
— Begin quote from memin;390660
oh by the way the model is WCSR4170DAWW, thanks
anybody?this forumSUCKSSSSSSSSSSS
— Begin quote from memin;390717
this forum is the best you must learn how to use it.
If your not up to diagnosing and repairing your stuff. Actuall hands on. Its not for you. By the wayIm in the same GE boat as you so good luck to both of us!
