I have a ge washer that will only fill up and pump out. Changed the control circuit board, door switch is good, fuse is good but no luck. Tried to follow the instructions on the tech sheet as far as running a systems check but could’nt quite understand. Teh sheet also has codes for the motor inverter board but I don’t see any flashing lights. help!!
Related topics
GE Washer dead | 2 | 1707 | February 20, 2009 | |
Ge Washer | 2 | 1308 | January 13, 2010 | |
GE washer won't agitate or spin | 2 | 4103 | May 25, 2011 | |
GE Washer will not fill | 2 | 1500 | April 3, 2013 | |
GE washer won't spin | 1 | 972 | December 10, 2013 |
