Washer will fill and pump out water, but no washing or spin, also I don’t see any LED flashing on the motor ? any schematic for the motor ckt board out there ?
i seem to have the same problem, it will fill up then you have to manully start it on the wash cycle and continue with each cycle manually, i suspect the timer might be bad on my machine. i did the reset procedure(unplug for 20 second and open/close the lid seven times) after doing that i can hear the timer working again…but still stuck in one place, will keep working on it.
