my washer will not drain any water, it would only spin on the slow cycle.
it looked like the pump motor was burnt,is the does the pump assemble come with that motor?
The pump assembly consists of the pump and the motor. You also have to check the hoses connected to the pump for any clog.
- The drain pump assembly WH23X10013
Here are the breakdown diagram and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=230385
