GE WDCombo - Cycle won't advance
Hi everyone,
Newbie here.
Recently, we’ve discovered the washer-dryer combo’s wash cycle wont advance, even thou all operations are functional.
Specifically, the timer-washer wasn’t (and still isn’t) advancing when we start a cycle, whether Regular, Delicates, or Perm-press. It just stays at the cycle. The WM is operational, as it Agitates, Rinses, Spins, etc… but it the timer doesnt progressively advance to complete the cycle, it just continues the current operation until I manually turn the dial to advance. For instance, if I dont manually advance the dial of the timer, the Spin cycle could spin for 30 minutes +. Does anyone know whether it’s the Timer-washer that’s faulty? I inspected the Timer unit (DIY from back of Control panel) and the gears seem to be intact with no damages. Again, I am able to advance the cycle manually, and the machine’s operations are working.
Any advice would be much appreciated… cost effective preferred.
Thanks in advance.
Frank
