Replaced the broiling element in the lower oven but still not heating up.Everything else seems to be working fine.There is a steady (for the lack of a better discription)whirring/clicking coming from the control panel whenever i attempt to activate the broiler in the lower oven only.Any help in pointing me in the right direction would be greatly appreciated. I have even switched wires from an upper element to the lower broiler element and to make sure the element works and it heated up just fine.Also cannot get the codes to display.All thar shows up are---- ------ dashes. Please,can someone help me out here.You just might save a marriage. thanks in advance
Steven Ladd
