Top oven only broiler element working
Maytag Gemini double oven- broiler element works in top oven but bottom one does not. Replaced the element but still not working. Could it be control panel issue?
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=mer6772baw
Here is a manual.
You will have to join the site and be logged in to be able tro download the manual.
http://appliancejunk.com/forums/index.php?action=downloads;sa=downfile&id=390;t=1413453742
Your units wiring is on Pages 6-9 and 6-10.
I am assuming that the oven either stays in pre-heat (never comes ready) or takes a long time to reach the set point temperature.
Most likely it is a control board (item 2 in section 02) problem.
I would check that the wires to/from the element is OK.
