general electric dryer won't start
The dryer won’t start. I have checked the power supply, and I am getting power.
I also cheked the start switch for continiuty and it is ok.
Waht else should I checked?
Thanks but, I checked the door swicth and it has continuity.
What else should I checked?
i have a whirlpool dryer with the same problem my dryer door switch has a brown and blue wire on the left side and a white on the right i checked the blue to white and get a connection but when i check brown to white nothing ? is switch bad?
Check the bottom element for any charring, if none seen remove the element and check the connectors and wires attached to it.
Let us know what you find.
Nat
The tub won’t spin. The machine will cycle manually and the motor works fine. The drive coupling from the motor has been worn out, torn out and the remainder of it was lying on the floor under the washer. I need a new drive coupling which I will order, but I also need to know the procedure for changing it out. Please help. Thank you. Lou Agathos
This page should help you with this http://www.appliance-repair-it.com/Whirlpool-washer-disassembly.html
