Getting error code display on indicator "Er" & "uo""
Dishwashing cycle won’t start. It will start off sounding like it is going to start working then it cuts off & displays the codes "Er" & "uo". I noticed the last few times that I was able to use it, it would not cut off after the cycle ended. I need to know what part is needed to repair it. Any advice is appreciated!! :slight_smile:
