Grease spots on clothes from dryer
Anyone ever had an issue with grease spots on clothes from the dryer? It looks like the clothes are getting pinched, I did find some grease on the front of the drum(behind the door) cleaned it and found a little play in the drum. I aslo noticed one drum slide is worn thin(possibly the cause of the play). If it is the drum slide causing this issue has anyone replaced them? Easy? Hard? Good site for direction?..Thanks RelicHunter
