The boot seal ripped and some water got into the door lock. I opened it up and found a spot which showed a small arc.
When I try to get into the test mode the washer beeps twice and nothing shows up on the screen. when I turn the dial it shows the cycle time with a decimal point and the buttons do nothing. Any I missing something? Also when I plug it in the pump runs. I’ve cleanded the filter.
I’v messed with it some more. The pump doesn’t run any more. When I press start the time counts down in min & sec. It doen’t fill, spin or anything.
Is there any tests to do on the board?
