Having trouble getting to chopper
My upper spray arm is not rotating and thanks to what I’ve learned from this sight it’s most likely a clog somewhere. I want to get to the chopper to see if it’s full of stuff but I’m having difficulty prying open the protective cover. I actually broke the tab!! If that’s not the culprit the next area to look at is the inlet hose.
  1. Does anyone have any tips as to how I get this sucker open?
  2. Am I on the right track with my thinking?
Thanks in advance,
BC
You can find some useful information in one of our previous posts: http://forum.appliancepartspros.com/dishwasher-repair/2903-whirlpool-dishwasher-2.html
The following may also help:
Parts breakdown
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5137425&diagram_id=958689#d958689
Tech sheet with pump repair info
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208557727.pdf
Gene,
Thanks so much for the useful information. I was able to finally get it to pop off. Now I’m faced with a chopper blade that completely sheered off from the assembly.I’m off to order a new chopper and check valve. How does this one come out? I tried lining up the notches in the screen with the housing and lifting and got nowhere…ditto when I tried to push on the spring behind the screen. Please advise.
BC
You can find the instructions in the tech sheet provided by denman. A small pliers might help.
