Just purchased this less than two years ago. The control panel seems ‘stuck’ in that it recognizes the dishes as clean, and won’t start a new cycle. I have tripped the power, but that doesn’t reset it. Had a repair man out here and he charged me $263 to install a new switch in the control panel. That worked for two loads and now it is happening again. He has quoted me $175 for a new control panel. Together, that is the cost of the unit. Please help! Is this fixable, if so what is the part?
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=GU2700XTSB1
Here is the tech sheet
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%20W10130990.pdf
Is this the electronic control board, Item 11 in Section 2?
Cannot really tell what was replaced from your description.
Also your description of the fault is pretty vague.
Is the unit totally dead no lights, no nothin?
What if any lights are on or flashing?
Have you tried other options etc.?
All I can suggest is that you try running the diagnostics.
