help getting tech sheet
Missing tech sheet. Not heating. Already replaced element.
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=wdt710paym
See the attachment for the tech sheet would check at the control board ( P4-4 to P4-3). Should be around 30 ohms. That way you check the wires, the heater and the hi-limit in one go.
