help how do you speciffically replace washer timer on Maytag washer
Help
how so you speciffically replace the timer on a maytag 10 year old washer for the taking off the large white timer knob:)
If you can post the full model number I am sure someone can help you.
Thank you model number is 2200152 of timer
— Begin quote from sidfink43;103798
— Begin quote from stupid1;103810
Model Number of washer is L A T 8 6 2 4 A A E
Ok, you need to take off the cover to the console, it is held on with two screws. Then you do the following.
  1. Pry the cap off the timer knob. This will expose a clip which you can remove. Then you can take off the knob, and there will be a spring and the dial come also come off.
  2. You can now take the screws out of the timer and it will come off.
Good luck, let us know if you need more info.
I will take it from here, I thought you would have to take the entire top of the control panel off or take the back panel off the back of the machine to get to the timer and the corresponding wiring.:slight_smile:
— Begin quote from sidfink43;103836
