I ordered what should have been the right parts (part # AP3083556), but the "holder" that holds the white part (sorry I don’t know my terminology, but you can see the image when you search the part no.) and the other part (which is black in the kit) aren’t fitting inside the holder. Actually, the white piece fits fine. The black piece not only doesn’t fit but has different connection prongs than the original. The holder piece has "4SP" molded into the plastic and under it are these printed numbers in three lines:
4SP1001
2212194
28 M01R
I appreciate help in finding this 4SP piece and the innards. The original piece when I opened up showed a black heat mark and had broken pieces of a silvery metal like material.
