Help putting dryer belt...Someone help pz!!
I took my dryer apart and brought a new belt, but I am having a hard time putting it back on :frowning: I’ve been trying for a week can someone plz help! I can post pics
Your image was banned for some reason.
Perhaps a model number would help.
Also a description of what exactly the problems is re: getting it around the idler wheel etc.
Ok thnx for responding I will post model number in a few, I already have new dryer belt on(no problem), but when I put it through the pulley(like 10diff ways) the belt is loose?! Idk why
See if this helps.
How to install a belt on Frigidaire dryer
Belt Type: Flat belt with ribs
Installation Notes: Ribs go against drum
I tried that way too…do u guyz kno a site where I can post a pic
Model # 1041AS2
Sorry I cannot find any info on the given model number.
To post a pic you could try datafilehost.com
Or
try insert image icon (picture with mountain in it)
Ok thnx for looking, I will try that site and post a pic when I get home! Enjoy your new years I appreciate your help…
— Begin quote from denman;640492
Or
http://www.datafilehost.com/download-95c86a19.html
Here are some belt diagrams.
http://forum.appliancepartspros.com/dryer-repair/25860-dryer-belt-diagrams.html
Yours should look like the Franklin just with the idler on the left not the right.
Using your picture.
Remove belt from idler wheel.
Pull (tension) idler to the left,
Place belt on motor pulley. Groove side faces the pulley.
Gently release tension on the idler so it rides on the left side, back (smooth) side of the belt.
Thnx so much finally have it put together :slight_smile:
Glad you got it back together.
For future references I started to put together a gallery of dryer belt and pulley idler images here.
Dryer Belt Diagrams & Photos
