Help replacing power relay
The display went out completely on my Thermador double oven. After viewing other posts on the web, it sounded like an easy fix, so I bought the kit, which includes a new display head and power relay board.
I am having trouble accessing the power relay board. OK, this is a dumb question, but how much do I have to disassemble to get at the thing? I was trying to pull the jumpers off by reaching in, but with only about 2.5" clearance, I can’t reach the back ones.
I removed the glass control panel carefully, and the display head, and the metal covering that gives limited access to the board. It would be a lot easier if I could slide things out, but I don’t see how to do this simply (i.e., in a way that a klutz like me can make sure I put it back correctly).
Thanks for any advice!
Grapes
Many thanks Gene! I managed to reattach the original board without damaging anything. With the new display head everything looks good.
I just hope the old power relay board/design doesn’t somehow burn out the new display head.
Again, thanks. I would probably have continued to disassemble the oven if you hadn’t warned me.
Grapes
Hi dzd9fy
In most cases is enough to replace just the display board and the harness.
  • The part number for the new kit (the Thermador does not sell the display board separate) AP3383663
Good luck.
Jim,
Thanks so much for your help with this. I have replace the display three or four times in the last 12 years and finally decided to replace the power relay board, too. In the past I was afraid to pull the oven out of the wall but you made it seem so easy, I figured I’d give it a try. I pulled the oven out about six inches and removed the black metal cover. Then it was a cinch to replace the power relay board. Hopefully, this display will last longer than three or four years. On another note, before I read your directions, I tried calling Thermador aka BHS. They were absolute jerks. The person I spoke to would offer me no help since I was not a certified technician. I said I wanted to speak to a manager and he put me on hold. I was on hold for around 30 minutes (while I researched your article) and then the call just dropped. Considering this is the third or fourth display I had to replace (I told him this), I thought they would have given me some help. But no dice. Thanks again for your help. And to anyone who’s replacing the display, you shold probably replace the power board, too and maybe you won’t have to replace the display again.:slight_smile: :slight_smile:
As you will see, I replaced the display and relay about 6 years ago. After a recent power outage with a brown out, the lower element of the upper oven is not heating. I pulled the element and the impedance is 19 ohms, so i think it is good and guessing it has to be the relay? The broiler works if that is of any help…
Very likely the relay board failed due to that power outage. I’m sorry for such sad news but this relay board is no longer available. You may want to pull out the relay board and check the relay which is responsible for the upper oven bake circuit. If this is just the relay failed then you can fix the problem by replacing just the relay. Otherwise I’m afraid it’s time for a new oven.
