I tried to fix my thermador double oven display, did I break it?!
Ok, I am a "do it yourselfer" only in my mind, I am occasionally successful, usually make a bigger mess. Anyway, I have a thermador double oven that the display has gone dark, and I don’t want to pay $500.00 to fix it, so I searched for answers and found this site. I was very excited to learn about replacing the capacitors as a fairly easy fix. I took off the cover of the touch pad panel and unplugged the long white (approx 1 1/2") bar and the small (square w/ 4 prongs) plugs w/ wires. Then I took the small display board to the electronics place to order the capacitors.
When I took the display board off the first time, I didn’t unplug the big cover panel, and when I put it back together, the oven still worked. This time it didn’t. I don’t know if I might have plugged the little black plug w/ 4 prongs on backwards and if that may have blown in internal fuse…
I am just wondering if I broke the whole thing. Does anybody have a suggestion or should I just call a repair person? I would appreciate any suggestions - Thank you!
