Washing machine goes into wash stops along the way with an error code. it beeps 3 times then flashes once. not sure if im reading this correctly as f0e1 the manual says with that code washer is detecting a load during cleaning cycle, or mechanical friction. Unit is not in cleaning mode and drum appears to spin very smoothly in both directions. any ideas?
it washes for a little bit then stops always in the same spot never makes it into spin cycle
