This started have the washer making a very loud noise when spinning. So I replaced the tub bearing, the transmission, the tub bearing washer, the split ring tub bearing and the tub seal. Now there is no noise when it spins but it is leaking and looks like it is coming from where the transmission meets the tub. I have replaced the split ring tub bearing, the tub seal and the tub bearing washer and IT STILL LEAKS. What can I do?
Your model number is invalid…Buy a new machine sounds like you botched the installation and should of hired a professional…you may have caused other damage by your installation and continuous motor leak on electronic parts…
Try this WJSR2080V3WW, see if that works!
